Discuss Running permanent extension lead from FCU socket? in the DIY Electrical Advice area at ElectriciansForums.net
Mormakil
I have installed a new dishwasher, unfortunately the new cable will not reach the socket. The socket comes from an FCU, but is impossible to get at to add an additional socket. Can I run a permanent extension lead (appropriately 50cm) to plug in the dishwasher?
thanks people:)
Reply to Running permanent extension lead from FCU socket? in the DIY Electrical Advice area at ElectriciansForums.net
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
