Hi
I need electrician mate or improver to help me carry out installation for fire alarm.cables in Central London
Start from tommorrow or Monday morning
Work is in construction site CSCS required
Work.is availble for 4 weeks at moment
More work will follow after that
Contact me using the forum to get phone number and email address.
Hello All,
This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its supply will be 208VAC 3 Phase, totally 4.5kW for whole chamber(3 Layers totally, individual layer has 1.5kW each).
The below image explains how the heaters are mounted in the chamber. Let me explain how it is mounted.
1. 1 number of horizontal heater (90 - 120V, 320W x 2 = 640W)
2. 2 numbers of Vertical heater (90 - 120V, 215W x 2 = 430W+430W = 860W)
So total 1 Layer will have 1.5kW and total 3 Layers of heater for the Chamber and load will be 4.5 kW, incoming phase of 208VAC.
We need to have a closed loop control system for the heater. As per my understanding, we need to step down the voltage for the heater, and on the transformer's (6kVA is enough for 4.5 kW) primary side, we need to use a thyristor. We took 57A thyristor.(TPR-3000 Series - Thyristor) (PID Controller)
The thing is i just selected the thyristor for whole load 4.5 kW. Should I select the thyristor for individual heater, since they are two different watt heaters (320W & 215W).
Please help me on this. Thanks!!!!
Hi,
I hope you’re all well. To cut a long story short, I’m going to be a young Dad very soon and need some help/advice/peer review with an electrical installation design project I’m working on(theory/written).
It’s mainly cable calculations I need checking/proof reading.
Everything is fairly overwhelming for me at the moment so any and all help will be extremely appreciated. Please contact me at StanleyAlanGregory@ protonmail.com if you’re interested in helping me. I will forward what I have so fair once contact has been made.
Kind regards
Stan
Hello, I hope you are well, a friend has lost power and it's the main switch that has failed I've got a bunch of different brands in the garage, does anyone know one which is compatible till Monday? Fairly modern one looks like Wylex style
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be posting it.
The other day, my wife plugged in the vacuum cleaner and the whole living room circuit went dead. I figured that it was just either a problem with the vacuum cleaner, or else maybe the circuit breaker, or maybe a tripped GFI. However, the vacuum cleaner worked just fine on a different circuit, and when I went to the breaker panel, I could see that the circuit breaker hadn't tripped and was working fine, since, when I switched it back & forth, it sent power to the dead circuit each time I switched it on and then checked with my voltmeter; i.e., each time I switched the breaker on, a given breaker box would show 120 volts between the 'hot,' black wire and ground. To check the two GFI's in that circuit, I saw that neither had been tripped, and just to be sure, I reset each of them twice, all to no avail.
So, having ruled out the vacuum, the breaker, and the GFI's, my next guess was that I had a bad neutral-wire connection somewhere between the breaker and the dead/bad outlets. To test this, I just grounded one of the outlets' white neutral wire and, sure enough, that did the trick, as I then had power to the outlet.
The problem that I now have is how to find the location of that bad neutral connection, which is where I need some helpful advice.
My game plan is as follows; please tell me if I'm heading in the right direction or if there is a better method of doing this:
1. After removing my temporary 'test ground,' so the whole circuit returns to its 'dead' state, identify what is on that circuit (outlets, lights, fans, etc. To do this, I will just look to see what is now dead even when being turned on.
2. Starting close to the breaker panel and then working my way toward the end* of the dead circuit, inspect and test each load in that circuit, looking for a loose or broken connection.
*To find the end/last load in the circuit I will just look into each junction box until I find the one which doesn't have any wiring continuing on to some other load; i.e., I will look for a junction box that has only one 'input' wire/cable and no 'output' cable going to yet another load.
Any other tips, ideas, hints, precautions?
All help would be much appreciated as I don't really know what I'm doing.
Hi, Ive got a couple of Megger PAT 450 testers, and, for a number of reasons, Im not happy with the printer it comes with.
Does anyone on here use that tester? what I'd like is an option to print a branded barcode/pass label with my company details on it, I've spoken to Megger and they wouldn't give much info bar telling me the printer I have is the one that they supply!!!
TIA
Hi all.
OK... Let me just try and clear a 1" square space on the screen inbetween all the highly intrusive ads....
On a site (NHS in fact) and they have SolarEdge inverters of which a few appear to have failed. I don't normally touch anything solar (17th edition here.... just doing 18th).
The original installer has walked away and Solaredge refuse to help.
We were asked to find out why they cannot talk to the Inverters over GSM. I think it's because there in concrete boiler rooms with zero GSM signal (and they don't have external GSM aerials fitted).
Basically, the first problem I identified is that a couple of them don't appear to shut down properly.
From what I understand from the manual...
  • Turn off the toggle switch ( 0 position)
  • Turn off the DC isolation switch on the inverter
  • Wait 5 minutes for the DC voltage to drop (no LCD on these models)
  • The red LED should extinguish when the DC is safe
  • Turn off the AC supply
Problem is, a couple of the units never seen to indicate the DC has bled away. The red led stays on and the green led (AC supply I believe) continue to stay illuminated for 20+ minutes.
Therefore, I refused to open these inverters.
Any ideas?
Hi there !
I'm looking for answers about the electrician industry in the UK in general for a service I'm developping.
That'd be really nice if you could answer honestly :
  • I need to know what's the average revenue per job for an electrician in the UK?
  • How many phone calls and missed calls do you guys have every week ?
  • Do you feel like you lose business because of the calls you miss ?
  • About the high number of phonecalls you might receive everyday : is it a source of frustration ? Do you feel like you spend your time on the phone ? Or not at all ?
Thanks a lot for your answers guys, really helpful !
I'm solving issues liked to an increasing number of phonecalls for business owners and I'd like my solution to be as relevant as possible !
Cyril
hI Gent's.
I I can explain this spur line briefly, maybe someone can help me?
Everything is Spur, no rings.
Inside of the house and main fuse box 3-banks or MCB' left 1-RCD on right side each bank
On the upper bank there was is one space available on the top row, MCB's -1-RCD - MCB - RCD adding 45A 30ma R/Side.
A cable of +/- 40m 4mm2 4-core was installed from house to pool house and sufficient supply, even less with LED lights replacing Halogen several years ago.
Cable is L-Blk-Blu-N-GY PE Br spare unused or "strapper" iirc from years back.
Installed an enclosure under cover&high for power supply and 12v transformer lighting 2x11w.
Intended to use a second RCD 25A 30MA in the enclosure approx half way 20m+/-. Theory for it to trip locally in light transformer enclosure for lightin.
I'd like to utilise the Br-4mm cable and utilise it as it's available and reduce the Amps, even though it is fine without.
Just unable to work out how to do this and have two RCD's and utilise the Br-cable.
There is a spare MCB in the pool house for balance of AC current.
I'm sure I am over thinking this and missing a trick.:rolleyes:
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even so that doesn't mean it shouldn't be done properly!
So, here's the background: My van was built a few years ago, so it doesn't have double pole MCBs, although the ELCB is double pole. There is no main isolator (other than the ELCB) and it's a very small consumer unit (four ways) and I don't have room to fit a bigger one unless I can find a very narrow one that has more ways. I've just fitted an inverter and want to power the mains sockets when I'm not on site hookup (EHU) however to avoid the power going round in circles I need to stop the battery charger (and the fridge) from being powered by the inverter, which will be wired through a changeover switch (or maybe a relay/contactor) to stop the EHU input plug becoming live and the possibility of the inverter output becoming connected to the mains!
Questions:
1) Do consumer units have to always be metal now?
2) Do I have to have a main isolator?
I'm thinking that I'll replace the current ELCB and two MCBs with four RCBOs, one each for fridge, battery charger, heating and sockets. The first three will always be fed from the EHU supply, and the last switched between the inverter and EHU. Ideally I'd like to have room to fit a contactor with the coil fed from the EHU in the consumer unit as well, but that needs to be double pole and carry 16A, so I don't think I can get one that will only take up one way, even if I can find a five way consumer unit that will fit in the space of the current one.
Answers/Comments please! Thanks, Graham
Dear Forum Members,
I hope this message finds you well. I am currently in search of a second-hand Baker EXP4000. If anyone has a contact or knows of a reliable source within the United States that sells used Baker EXP4000 equipment, I would greatly appreciate your assistance.
Thank you in advance for your help.
Best regards,
Jesus L.
How do they get away with this?
I'm only fitting this mirror cabinet, but check out the "LED strip removal" instructions!
Also, the power off before maintenance or removal from wall is on a sticker on the back of the unit!
I know we've all come across such things before, but it never fails to amuse.
Hi all, got a customer with 3x 900mm straight double peg 110w bulbs/lamps.
It seems led equivalents of the S14S and S14D type are available, but nothing for S12RP (double peg) I've found a site that has old stock of 300mm incandescent ones, but i need 900mm. Anybody got some lurking on the shelf or know where does? I dont need LED, just new old stock of 110w if somebody does.
Electric hob/oven range was installed years ago, runs on 2 x B32 MCBs to 'House' (sub)consumer panel, runs to oven on 2 x T&E.
Kitchen is being remodelled. Would like to run cable direct from range to 'Plant Room' (main)consumer panel.
Need advice on cable purchase please.
1 x SWA with 4 cores?
2 x T&E?
1 x Quad&E?
Note:
Main consumer panel is located in 'plant room' (adjacent to house) per DNO requirements for GSHP. (SSE change of supply in 2021).
'House' consumer panel is connected to 'Plant Room' consumer panel using SWA cable.
Notes from range installer from years ago:
There is a requirement for an electrician to fit two 13 amp fused spurs. Each of the spurs must come off the ring main and not another spur, or have their own separate supply from the consumer box. This could be a split 30 amp supply.
The hob spur will be rated at 2.8Kw and the oven spur will be rated at 2.35Kw.
