I have three 6" LED wafers and a ceiling fan on the same circuit/switch. I wanted to control them separately, so I installed GOVEE smart lights ((H601A) figuring I could leave the switch turned on and control the lights from my phone and the fan with a remote control.
The fan line comes off the middle LED. If the fan is on everything works fine, but if I turn the fan off the lights flicker and will not connect to the wifi. Everything worked fine with regular LED wafers.
Any thoughts on how to remedy? Might running the fan off the last LED in the series fix things?
Thanks in advance for any suggestions! Richard
Hello. I have a Litecom CCD controller installed. When logging into the web interface at its ip address, it asks for a password, the password is lost. There was an attempt to reset the controller by pressing the Function button for 30 seconds, but the password still remained. There are no suitable instructions, except for the instructions for installing the controller, which mentions resetting using the Function button. If someone has worked with Litecom controllers? Is it possible to reset the controller to factory settings in order to get a new password?
I have a few 30 amp and 63 amp ottermill overhead Busbar tap off boxes for sale after a factory relocation, these are becoming hard to locate now, if you or your customers have this system in your industrial building,
They all have good fuse carriers and bases.
Hi everyone, I work for a team called Greenworkx, where we help people get into green careers by offering training and job opportunities.
One of the jobs we're hiring for recently are Electrician/Solar PV Installers from Essex and St. Albans:
Highlights:
  • Salary: £40K (don't be put off if this might be lower than what you expect, we'd love to learn about what your preferences!)
  • Hours: Full Time
  • Requirements: 3 years’ experience in the field & NVQ level 2 required
You will be carrying out installation of Solar PV Systems across a range of clients and contracts including housing association, private customer, and new build clients.
Interested? Comment below or send your CV to forum@greenworkx.org
Has anyone good or bad experiences with Qcells equipment and do they do a single phase inverter larger than 4.6?
Looking at:
Q.HOME CORE H4 batteries and Q.VOLT inverter
This weekend we have a selection of our best-selling lights available at a discounted price!
Missed out on our offer or looking for something different?
Discover our full range of competitively priced products available at Electrical2Go
I have a bandrecorder Revox A77 case model with speakers and amplification. Model MK4 from 1977. He had a total restauration and after everything was ok except that he would’t record with the Jack in the front. What could be wrong?
I have a recurring DC Interference fault on my solar system. I have gone through all the scenarios recommended by Solis, but still no solution. All I can pinpoint is that the fault occurs when the batteries have just equalised at 100% and there is an additional power demand such as switching on a kettle or washing machine. Any advice as to what I can look for? The inverter was swapped out by Solis last year but still no result. MY system is as follows:
17 JA solar 535W panels in 2 strings
Solis S5 EH1P-6K Inverter
2x Hubble AM-2 batteries (5.5Kwh each)
We have some very old delmatic lighting control modules that have pcb and relays for switching they have mostly burnt out. I need to change them for a modern control, I was thinking vitesse plus bit would the no volt switching work with this or should I just use a pir? Cp electronics want to charge £500 a day for a site visit. I could upgrade these myself but wondered if anyone has advice or a better solution? This is a large office space with emergency and standard fittings.
Hi,
I have a question
What are the most common causes and symptoms of issues with the main relay in an electrical installation?What steps should be taken to diagnose and resolve complex EMC disturbances in an industrial control system?
Jack:)
