Hi
Anyone using the KEW-80L thermal printer? I've only hit the second roll it came with and now it's spooling 2 labels out and often missing the label itself and printing over two. I've reset it, check settings are right, left battery out overnight etc, nothing seems to work.
Ironically it's come at my busiest time.
For what they cost new these things are a rip off, built like junk.
I thought it was the app or android issue so got my old phone out that used to work fine but did the same thing.
Still waiting for Kewtech reply.
I'm now in West Virginia but my wife and I also own a home in the Philippines. The current in our province is 240v, but single pole.
I have experience wiring houses in the US so I know that the 240v here consists of two 120v wires that are 180 degrees out of phase.
That brings me to my question. Some expats who are planning to live in the Philippines want to know if their 240v US appliances will work in the Philippines. I'm skeptical that will work but maybe I'm wrong. Could I wire a US appliance, like an oven, with 240v on one side and a neutral wire on the other instead of 120v on each side? Could I also us a Philippine appliance in the US by wiring it with 120v on each side like a US appliance? Thanks
Having some issues with my companys fluke 1662/1663 tester.
Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue comes doing the Zi (loop impedance) the instructions say to zero 3 leads for this test ( if you try to zero two leads L and PE it reads >3.00ohm) you have to zero with all 3 leads connected, the value for 3 leads is 0.14.
We have tested a sub main and the fluke reading is coming in at 0.04. Where as the megger another tester is using comes in at 0.11. The DNO value provided was 0.10 so the meggers test result seems to be more accurate. I know the megger auto carries over 0.07 to the loop test so you dont have to re zero your leads. This is causing issues on site as the fluke reading are lower and this effects the PEFC and PSCC as well as readings downstream of the submain.
Does anyone have any ideas, or does anyone use the fluke 1662/1663 series.
Its like the fluke should be only zeroing 0.08 on 3 lead null, but the tester has just come back from calibration with a pass and we've used brand new fluke test leads.
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the standard lighting for most rooms.
Then the residential energy saving craze began, 2 and 4-pin CFLs, starter vs no starter, 2D, U-shaped, M-shaped, spirals, Circlite and Circline -which despite their similarities, were not the same-, and many more, though this era of oddly shaped lights wouldn't last forever, around 2010 the very first commercially viable LED lighting solutions in a shape that resembled a standard light bulb began to appear, but they didn't make it to most homes until 2015 when mass production made them cheaper and more akin to regular light bulbs using a standard no-frills base, a direct replacement to incandescents without the hassle of rewiring or installing new luminaires.
As a sparky I've dealt with pretty much all lighting technologies, except for the elusive and now rare SLI/H.
But what's actually better? are LEDs miracle bulbs that will make you save hundreds a year and last for decades?
As with everything, I'd say it depends. On what you use, where it's installed, how, and what for.
Now, my experience with LEDs at home was... disappointing, I wouldn't define it with any other way, every time I wanted to "switch to LED and save hundreds a year!!!" I've sighed and felt I wasted my money, first of all 'warm' lighting isn't extremely popular where I live so I had to visit specific stores to get my hands on warm LEDs, bought Osram stuff thinking well it's a known brand and all, installed a few and... it doesn't looks at all like our regular incandescents, the brightness is fine but everything looks opaque or washed out because of the terrible CRI, the advertised 2700K CCT is nowhere near the same colour of an actual incandescent, I've left a few installed outdoors and they all started flickering or simply died less than 2 years after purchasing them.
These were retrofit bulbs, 100W replacements. I also tried retrofit MR16 GU10 ones, with the same result. I suppose I'll have to wait for a few more years to do the switch, for the moment we still use incandescents both regular and halogens in various shapes, and a pair of mercury vapor bulbs outdoors.
When it comes to working though... I'd say I'm disappointed in different ways. Had to install wafers and batten lights and I was never happy with the result, although the customers were satisfied with the results, I did warn them they're not gonna last for long without going into specifics, it's not uncommon for those to start flickering during their first year of use, it's usually the driver that goes bad due to overheating. Same goes for batten or panels that are supposed to replace linear fluorescents and troffers, I installed some at my workplace and 3 of them failed after 6 months of use, it doesn't help that the ceiling is insulated.
Thing is, you can't get anything that isn't LED anymore, third world markets have an obsession with always selling the latest products and keeping no stocks on older products, we're also heavily influenced by China as well as local retails depend on Chinese manufacturers and wholesalers have to offer. So, when doing any large jobs I must tell the customer I can only install LED because it's what's available.
If I'm in charge of sourcing materials I always suggest can downlights with regular ES base sockets or wall sconces that aren't integrated LED even if that means the same guy won't call me again to replace the dead integrated stuff in a few months or a year, some of you might think it's dumb but I'd rather lose those smaller jobs than cause the user a headache or have him call me angry because his super duper fancy LED sconce is flickering like a rave light.
Last job I did was wiring 3 whole apartments and I tried to make it as simple as possible, only regular downlights, a few GU10 spotlights and outdoor sconces, and regular ceiling fans, the ones you don't have to ---- in the bin when the light goes out and you can't find a replacement module because the manufacturer rendered it obsolete or it's not imported.
LED retrofit tubes.... terrible in every aspect, I won't even elaborate, I just avoid them.
Anyway, that's MY experience.
On the other hand, situation in other countries, mainly in Europe seems to be radically different, with LEDs that are actually decent and even emulate the looks of incandescents by making use of thin COB modules shaped like filaments, that's still unheard of in my country, and if it does come at some point it'll be prohibitively expensive, unless it becomes the norm in bulbs and the "ice cream" style isn't manufactured anymore.
Extra note. Ignore the US flag that appears next to my name, it was automatically added and honestly I have no idea how to change it or remove it. I don't live in the US. There's also a "1663" tag that was there upon making the post, for the sake of not breaking anything I won't remove it.
Made a little progress, decided to add battery backup.
This is just to get it up and running initially.
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this morning to test and was told that her cooker was tripping the rcd.
Before checking the cooker element I did an rcd test this morning on the left side of board (side with cooker circuit) and the rcd wouldn't trip. Did an rcd test on the right rcd and it would trip both rcds. Would touch neutral to earth on the cooker circuit and nothing would trip.
Anyway the fault was that a neutral was touching the outer casing of a light (see photo) that makes sense about the rcd tests, because the fault current the rcd sends out will go through the earth and back up the neutral cable of the lights and make its way back to the rcd.
I am a bit confused though on why this neutral to earth fault didn't just immediately trip the rcd? Am I right in thinking that it's probably due to the highish ze of the TT rod? So the fault current just wants to flow through the neutral as appose to the earth and it would only trip with the cooker because enough current is drawn therefore more fault current and more current going through the earth as well as the neutral
well now to throw some stuff on the tv wiring I did ages ago
I have a labgear 8 port distribution amplifier mounted in the airing cupboard (eventually I'll add a socket for it one day)
then I have a fm antenna connected to it and an older tv aerial in the back garden ran with a 20 ish meter maybe run of rg6 coax that runs up the back wall and drops into the loft through the eaves.
I then just used the holes the cold water pipes use to run into the cupboard where I added f plugs to everything and connected it (had to use f plugs to splice the stuff in the loft also which I have a plan to add a patch panel for also at some point to tidy it up
I did use some electrical tape on the older f plugs to help with holding them a bit more secure but I doubt it's really needed tbh
I'll get better images later
the cat 6 cable hanging down is for an eventual upgrade with running a line downstairs at some point
I have a Hoover HBCP3150, integrated fridge freezer. Probably 3 years old. It's immaculately clean inside and out. It looks brand new but the fridge is idling at 13 degree, Freezer is fine. I got a spare thermostat and took a picture as I unplugged it for the wires. It was only after unplugging it that I realized the picture didn't take.
I had 3 wires. Brown, Black and White. I put Brown to C (Power?), Black to L(Compressor?) and white to H(Heat)?
Turns out, the fridge still idles at 13degree. The spare part was from a salvage site so hopefully this was also faulty but I have a brand new one coming and I am just hoping this makes some sort of difference. Is the compressor faulty? The fridge has no vents or fans so I am guessing it's all static.
Hoping someone can help because there is no such thing as a refrigeration engineer in Ireland..
Got rid of mains relays and used 5v ones.
Sorted out a little charging circuit and change over for the battery.
Well today was great.......Missed a dhl delivery and then missed the closing time for the dhl service point (local post office) by about 5 minutes....lol
Looks like my stuff from prusa will now have to wait till tomorrow to collect I guess (they closed at around 5:15 ish...I went at 5:20 or so)
not the end of the world just a pain
waiting on some other stuff also for various projects atm (another plane tracker project) this time it will be hfdl so I had to get another sdr and also IO need to look into good antennas for it 💸.
this rabbit hole adds up haha
How is everyone elses day going
also waiting on amazon to ship my parts to get my pi boards in a proper case finally vs sat on the attic on some plastic which is annoying me (still going to need to print a mount to secure them but it'll at least be a start towards a more professional looking setup instead of a janky thing that looks like a danger to go near
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other features and I can't find the company wiring anywhere on line. Can someone tell me what the following means?
Mode Switch:
I know they are momentary switches but is this normally open or normally closed?
If this part on the race switch assembly was designed to use 3 switch (1 up, 1 down, 1 mode) does the earth run to all 3 switches. I think that is what the diagram says but don't want to hook it up wrong.
Stock:
Now button switches :
So:
  • Up momentary normally open switch = black wire and green wire
  • Down momentary normally open switch = black wire and green/black wire
  • Set/Mode momentary normally open switch = black wire and green/yellow wire
Is there any way to tell when a switch is momentary or latching from the diagram? I think I know from their function but just curious.
The bike also has a pit limiter that was latching switch replacing the indicator switches. On the race controls it is a single latching button switch. I think it has been wired to the left/right turn signals as this is normal practice. Is this normally open or closed? How would I wire that to a single button switch?
Thank you in advance
Hi all,
I’m looking to expand my knowledge and learn more around this side of the electrical industry. I’m a commercial gold card electrician (1.5year qualified) however 99% of the time the security etc is Subbed out to specialist contractors (probably for the best😂) and we’re so busy I never get the chance to learn from them.
I’m wondering if anyone has any recommendations of learning materials -websites, YouTube channels, instagram pages etc which covers this side of the industry that I could use to learn from in my own time to gain a better understanding of how it’s all done!
I painted a bathroom and must’ve gotten paint inside an outlet because it’s not working. Went to the fuse box cut it off and changed out the outlet for a new one as I was doing that white wire and black wire touched and sparked. Went back to the fuse box. Everything was fine and change outlet. Turn the fuse box back on outlets not working. What do I do now?
Hi all,
I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic (2nd photo is the original)
It has 2 neutral (both wired in N) + 2 live wires that i've tried both wiring in L and L1 and simultaneously in other multiple combinations but still no lighting outside. I've left the earth sleeved, disconnected as no place for it. I do recognise in the 1st photo (smart switch) that the 2nd neutral isn't in and have tried all combinations and now at a loss. Wifi connected to 2Ghz.
Any help appreciated
Best
Craig
