Hi Can anyone help me with a problem.I have to do a safety check on a couple of new static caravans.My idea is to do it in the form of a pir but does anyone out there know what reference method to use for the wiring? Any help would be appreciated.
Anyone every fitted a Chandeleir lift? Done one today finishing tomorrow, cool idea, allows you to lower the fitting for servicing, changing bulbs etc. Quite a nice different job anyone done this before?
HI,
I need an LEB electrician to move the supply and fit a new pme system to a property in edgware.
I have had LEB blokes move them for me in the past, but have lost contact details. Any help thanks
Hi we are looking to put an electric fire in our lounge instead of having work done to put a gas fire in, we currently have 1 raditor in the room
Please could anyone tell me what electric fire would i buy that would be as good as a gas fire ie having the same or similar output of heat The fire would be a feature in the room so would be putting the fire in a surround
any advice would be appreciated
regards ellie
ive heard niciec have a periodic inspection report course
has anyone done this course ? or know anyone that has ?
please let me kown
Hi all, got some skirting to fit in my living room and am looking for a decent mitre saw, not too expensive and gives a clean accurate cut.
Can anyone recommend one?
Hi all
I am not an electrician as you will soon see. I always each year decorate the outside of my house at christmas to raise funds for the nurse's at our special care baby unit who saved my little girls life many times. BUt have recently seen the American decorations that pulse to music. I have purchased a system via eBay that will do this and have some 110V USA lights to go with it. The problem is that it looks a bit weak so would like to add some more lights to make it look better. The only lights I have are UK 220/240v. I have tried buying a step down converter but they keep blowing as the power pulses through them. Is there anyway to convert these UK lights to work directly with the 110V output system I have bought. I am using a building site 3.3KVA transformer to power the main unit and it runs perfectly. Its just that in previous years I have only ever used our normal UK voltage lights and would like to get them all working with the American system.
Hope I have asked the correct way and maybe someone out there can advise me on if its possible and if so how to do it.
Many thanks
JG
HI everyone
I'm in the middle of some electrical line drawings and need the drawing symbol for a RCBO..... Does anyone know it or where to find it......
Cheers
come across a 32A circuit feeding 4 x 100w lamps fed via 6.00mm swa but at far end lighting is conected via 1.5mm flex .so in theory this cant over load 1.5 flex earth loop of .78 so can this be accipted as earth loop will clear fault under fault just as a 2.5mm t+e can be protected by a 32A breaker as max load will be 26A
if so can any one point me in the direction of the reg this is covered by
hi guys,
I am a newbie here and am to everything electrical. I am 31 and got made redundant from my IT job. I am in Ireland but I am very close to Northern Ireland which is where I would do courses if I was to take one. I have worked in IT for 5 years, I have a similar qualification to a HND here in Ireland in Computer Electronics. I like the Idea of being an Electrician as It is something I hope I could travel with. If work dried up in one place. I would like to get into electrical maintanence. I am thinking about finishing my degree but the job opportunities in my area are poor for this and always have been. I see being qualified as an electrician as being a good qualification for a single man willing to travel. But in the current climate how hard will it be to get some one to take on an apprentice, and are there too many apprentices being put into the system. Is it a bad area to get into now, and how will it look when a 31 is doing an apprenticeship
Paul.
Hi All,
I need a meter for ensuring Capacitors are discharged, they work up to 600v and are located in a place where a normal GS38 voltage checker wouldnt reach.
What I am wondering is, is there a multimeter that is rated safe for use for proving a 'dead' test. Basically I have to be able to change the leads so that they can be a form of long probe.
Cost isnt too much of an issue.
Many thanks for your answers
Forrest
i am taking my 2391 next week and i would find it helpfull if anyone knows where i can find last years exam papers for me to download ?
Hi all,
I am new here and I just need a little guidance on an issue I am having.
I purchased many years ago the following lighting rig. EVL Mini 250 Colour Pack.
Straight from the off this pack was giving me problems.
Whats happening is that after about 2 hours of use the bulbs blew on all four at almost the same time.
The pack consists of a central control unit that distributes the voltage and signal to 4 light units.
- It is uk mains powered and it is controlled by a dmx footswitch
- Power is 220-240v 50/60Hz
- Fuse is 5A
- Bulb is ENH 120V/250 Lamp
It is driving me mad!
The manufacturer does not sell this anymore and they ignore my emails.
Any recomendations?
Thank you very much
Hi guys
Just putting some final touches to an assignmet that needs handing in next week,
I really could do with some more ideas on the following:
*dsadvantages on having Thermoplastic cables
*disadvantages on surface mount cables in a busy shop
*disadvantages on Trailing Leads in a shop (Apart from the obvious trip hazard.)
With any references to bs7671 etc.....
Really hope someone out there can help as assignments really isn't my strongpoints.
u've all been brilliant so far.
Hi, are there any geniuses on here that are quite clued up with resistance in both series and parallel circuits??
I have just done an Microsoft Excel spreadsheet with a few formulas on and wondered if you would mind downloading it and testing it for me?
I have put it on my webspace: http://www.eskimo-design.com/resistance_calculator.xls
There are 4 different sheets accross the bottom tabs, 1 for series and then pages for 2,3 & 4 resistors in parallel.
Also can you tell me if the total power in a parallel circuit is still VoltagexRt
Thanks very much
