Discuss 2 Wire Copper circuit in older home in the DIY Electrical Advice area at ElectriciansForums.net
Without running new wire or at least ground, next best is GFCI receptacles for limited protection. I know about a bootleg ground to fool a tester. I am not going there! Does each receptacle need a costly GFCI or can standard receptacles be used down stream on the load side of the first GFCI and still get the same limited protection. I will use the stickers "No Equipment Ground" for future users and or home inspectors. I just need 3 prong plugs.
Reply to 2 Wire Copper circuit in older home in the DIY Electrical Advice area at ElectriciansForums.net
Hello, I had an electrician install GFCI receptacles (as per their recommendation) due to my homes older electrical wiring. I also have...
I have a small power washer with a two-wire cord and GFCI plug. My outdoor and garage receptacles are on a "house GFCI" circuit, wired in series...
My 1951 CA home (none of original wiring grounded) has 7 receptacles* that have a separate ground wire extended into the subfloor and connected to...
Hi there. I am a doing some DIY kitchen work. In Ontario Canada, code allows either a split 15 amp multi-wire circuit or a 20 amp circuit (each...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
