Discuss 50mm (2x2) clear services void between plasterboard ceiling below and vapour barrier above: in the UK Electrical Forum area at ElectriciansForums.net
Deleted member 150200
With current regs is 50mm enough, I know in floors they should be 50mm clear of the plasterboard, but this is a flat roof with vapour barrier and insulation above. Secondly would you agree that the cables should ideally be clipped with metal clips due to new fire regs.
Reply to 50mm (2x2) clear services void between plasterboard ceiling below and vapour barrier above: in the UK Electrical Forum area at ElectriciansForums.net
Hi I have to run a feed to a CU in the middle of a ground floor flat . Its already got 2 layers of blue board and 100mm rockwool above it . It...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
One of the oddest jobs I've ever had today. Called by a plumber I know who had attended after a leak through the kitchen ceiling from bathroom...
6K
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
