Discuss DIY Shelf grow light strips and dimming in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm very new to electrical but I'm ready to learn. For my first project I'm looking to setup 2 shelf racks with four shelves each and about two feet long each. For my project I'm going to be lighting grow racks for plants, tissue cultures etc. I'm purchasing 2 rolls of dimmable 5630 cool whites, one dimmable 5630 red, and a blue.
here's my main question, i want to be able to dim each shelf separately, and the red separately from the blue , and same with the white. firstly for this project would it financially reasonable to be able to dim each color individually? how would i do that? is it possible to wire two inline dimmers to one led driver? I've heard of pwm dimming working on non dimming power supply , is that feasible? i don't really understand the other types of dimmers and how to wire them in yet. but if you have a suggestion of something definitely let me know. these two shelves are only the beginning i want to learn how to most efficiently power multiple areas with solid color leds. whether it be one large transformer (it doesn't look like they come with an outlet connection) or multiple small drivers I'd like to know the best way to come about this.
also with the 5630 led strips, if i don't mount on aluminum it will cause problems right
TL;DR
how to wire dimmers for plant grow lights (multiple solid color led strip)
Reply to DIY Shelf grow light strips and dimming in the DIY Electrical Advice area at ElectriciansForums.net
hi im looking to solder solid-color led strips to one power supply for each color, in order to dim each color individually. this is reasonable...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
