Discuss Trying to figure out amps in sub panel in the DIY Electrical Advice area at ElectriciansForums.net
30603080
I have a sub panel about 75ft from my house attached to my shed that feeds a pool pump, some outlets and a pool heater which is no longer used (50amp). I have built another shed 30 ft from the sub panel which I want to bring power to. I need 1 - 30amp outlet and at least 2 - 15amp breakers to feed maybe 6 or so outlets. I will be installing an 8,000btu ac, a low watt tv, switch for internet and that's probably it. I will be using the 30amp for a couple of crypto miners that use 10amp (2200 watts each) plugged into a pdu. So I am trying to determine how many amps have been brought into and the sub panel. Currently I count a total of 175amps based off the breakers. I no longer use the heater for the pool so that alone is 50 that I can use but not sure how to determine how many other amps are available. How can I tell? 1.jpg
Reply to Trying to figure out amps in sub panel in the DIY Electrical Advice area at ElectriciansForums.net
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
Reaching out for some help/guidance and sanity check. Apologies in advance for the long post, but wanted to make sure it was clear. Thanks in...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I am trying to understand the amperage flow in my 200 amp main panel. In theory, (example only), let's say you had a 200 main panel installed...
